Sorry, but there's nothing wrong with the manual. Like a lot of other user guides, it helps to have adequate knowledge when you start reading it.............I've been there and dealt with it. If you are having problems with the S/craft manual, God help you if you ever try and follow something from Fostex or some other Asian companies
OK, on to the "outs", as shown in the manual..............the monitors should be connected to the "Control Room" outs, the volume is initially controlled by the Master fader and the rotary "C/RM & PHONES" pot allows you to make further adjustments without altering the main mix volume. BTW, connecting h/phones to the "Phones" socket cuts the signal to the "Control Room" outs.
FB 1 & 2 outs are to feed signal to headphone amps, etc.
"Mix" outs are connected to either a 2 trk mixdown recorder or a computer.
Hope that helps.
