I have mixed on comparable models on some of those mixers that are listed. It is STILL my opinion that the Ghost holds it's own against them.
Another thing skippy didn't point out, actually a few things:
1 - You have no warrantee with used consoles like them. And, you have no way of knowing just how good of shape they are in. Did they do a temp fix on a Pot that is faultering? Or was it replaced? You won't know until you run it 24/7 for a month or so.
2 - Many of these older consoles used relay switching, which has proved to be a bitch to deal with when those relays go bad...
Also, muting on many of these consoles are done so with a "hard switch", which CAN be very noisy. I forget what they type of mute switch the Ghost uses, but it is a "soft switch", which mutes over a period of 10ms, rather than breaking a physical contact. It almost never produces a "click" on the channel when engaging/disengaging the mute. This is significant. I remember on a mix I did on a DDA long ago where we had to do a VERY fast fader move to remove some noise in a "dead" part of a track right after a musical part on that track, because when we tried to mute it, we kept hearing a "click". We started paying very close attention to this problem, and it wound up popping up throughout the rest of the mixes too!
I just never had this kind of problem on a Ghost when muting. In addition, the "soft mute" has a very musical application when you are trying to tighten up some stuff together when engagin/disengaging mutes. The 10ms "fade out" and "fade in" can be a nifty little thing to have when compared to a "hard" on/off.
3 - You are going to have a bear of a time finding competent techs to work on many of those consoles. Repair costs (and if the console was WELL used by the prior studio) are going to run you higher. In addition, parts might be a bit harder to find. You might be in an area where there are a lot of techs that can service those consoles and have access to affordable parts, but in the case of the Ghost, it is STILL produced, and Soundcraft makes the parts easily available to repair shops and offer those shops good support for fixing their consoles.
4 - In todays modern studio, the Ghost really does offer built in features that are handy. SMTPE time code reader/generator. MMC. Dynamic mute automation capable (with snapshot automation built in!!!). These are all things that will get USED in a somewhat elaborate setup. The Ghost CAN be fitted with VCA fader automation, but you will have to look around a bit for this package (there is some info on the Soundcraft website. I am not sure if the guy that created the automation package is still producing it or not, but he would probably know who HAS it, and one of them might sell theirs....who knows...).
Those consoles listed are very good consoles indeed. I am not sure if sjoko2 had ever USED a Ghost before in a serious way to compare it fairly. I HAVE against like what I said earlier, consoles of the same model, or comparable to those he listed. While I will in no way try to compare my knowledge, experience, or judgement to sjoko2's (shit, he was mixing when I was born!!!
), I am no slouch when it comes to hearing what sounds good and what doesn't. I found myself WANTING the Ghost when I did some mixing on Tridents and DDA's. Those TEC consoles are noisy, and wouldn't mix on one if I had a Ghost available somewhere else to tell you the truth (or maybe the one at the studio I checked out had some problems...hard to say, but this studio has an owner that is a electronic tech, and he generally keeps his gear in tip top shape, so I just suspect that TEC console was just in fact, noisy....).
Anyway. Tough call. I certainly wouldn't turn my nose up at many of those consoles. But if I was buying, one of them would REALLY have to be mint for me to purchase it over a Ghost.
Ed
