I got one too.
For some time ago I bought a Tascam 38 (reel to reel deck) and I had to get a couple of preamps to feed the 38 with. When I spoke to my local music store I learned that I needed direct outputs to adjust the proper input level, to get the desiered amount of tape saturation. The FX8 gave me that option and with a proper monitoring.
Since I normaly do not record with my Tascam 38, I have the FX8 hooked up to my PC DAW.
I use
a Wamirack 24 soundcard with 4 in 8 out. I have connected 4 of the 8 outputs to the FX8's stereo channels which gives me a better monitoring than before.
Previously, I've been using GigaSampler (with no FX options what so ever), so the built in lexicon FX was really welcome when playbacked (orchestral samples are in my opinion easier to play with reverb), but not when mixed down.
The overall quality of the lexicon FX isn't really that good, it works for playback while tracking, I belive there are plugins that are better to use in mixmode when working with a PC DAW.
Since I've upgraded to
GigaStudio 160 I've no need of the lexicon FX.
I got the FX8 on a pretty good deal so that was the best option I knew at the time.
Soundcraft have their new M serie mixers which has the same preamps as the more proffessional Ghost mixers.
I whould recommend that you take a look at the M serie mixers. I belive the M8 is cheaper than the FX8 but the M8 has no built in FX, but instead 4 stereo channels and a digital output.
I think that the quality of the preamps in the FX8 are decent but not great, and I do belive the preamps on the M serie mixers are better, but I don't know how much better. I can only come to the conclusion that if I where offered to trade my FX8 to an M8 I wouldn't hesitate.
If you have a lot of external gear and only record 2 tracks at the time you might also check out the Soundcraft E serie mixers, which unlike the M serie has no direct outs on the mono channels, and I know there is one modell of the E serie that has alot of stereo channels(if your external gear are of that sort).
