B
		bluesmouse
Okay everbody, I promise this will be my last soundcard question...
I've decided to buy the Audiophile 2496 instead of the Delta 44 because then I'll have access to midi if I ever need it. But before I buy, I just wanted to check something out with you guys:
I'll only be recording 2 things at once (a couple of microphones) through my Behringer UB 1002 mixer So will the Audiophile's two inputs be enough? Do the two mics just run through the Behringer and then one output from the Behringer goes into the soundcard?
Would I be likely to need 4 inputs in the future for something other than recording lots of instruments at once?
If I bought the Delta 44, could I just get some kind of converter later on so that I could hook midi instruments up to it?
Thanks,
Bluesmouse.
Thanks,
Bluesmouse.
