DogFood said:
You put this stuff under your drywall during construction for sound deadening.
www.aknightcompany.com/productline/soundstop/ss_overview.asp
is there a better product out there for this purpose?
Sure is - it's called drywall.
The problem with this material is that it has mo mass in comparison.
1st off - don't be impressed with an stc rating of 42, that wouldn't pass code for even between hotel rooms, and you aren't concerned with anything even remotely coming close to studio frequencies when you see an STC rating.
STC is essentially a ratiing that was designed to keep people from hearing you when you have a conversation next door to them - and therefor only deals with the frequency range of the human voice.
When it comes to pro studios and you begin talking frequency ranges as low as 10Hz - it takes the right amount of stiffness and mass to attain anything even close to what you need.
This is not a bad place to learn about building a home studio - but if you plan of getting into this professionally - you are going to need a lot more than what's offered here in the sense of the concepts behind acoustic isolation in a pro sense.
Visit
http//forums.studiotips.com
if you really want to learn enough of the theory to be able to make an intelligent descision on behalf of a client. Understand though - if you really want to learn - as opposed to making believe you know - you have one heck of a long road ahead of you. This is one of the most involved engineering areas there is - and the biggest challenge is that just become something seems to be intuitively obvious does not necessarily mean that it works. Sometimes it's just the opposite in fact.
BTW - I know this to be the case because I am in the field - have built, designed, and been team leader for the design teams for world class recording and movie studios. Tain't nothing easy about this one.
Sincerely,
Rod
