jumpingpound
Hello All,
I'm a new(er) using to Sonar and have just put Sonar 8 on a new PC with an Auzentech Prelude 7.1 soundcard. Everything with the audio on this computer works just fine, except for an issue in Sonar. When I record an analog device such as my guitar (through a POD XT) into Sonar, the recording comes in with a series of gaps in the information that come across as small pops. When I record using the windows recorder or the prelude's recorder it works just fine with no such problems. The "gaps" in sonar are hardwired into the recording, and are visible in the waveform itself (see the attached image).
I've read every help file and looked all over the internet for a solution to this problem but can't seem to find one. I've adjusted the buffer settings repeatedly to no effect, and I'm not sure what to make of the issue. During both recording and playback the CPU meter is very low (less than 10% usage) so it's not as if I'm maxing out my system. MIDI recording and playback work just fine.
Any help you could offer would be much appreciated. Please bear in mind that I'm more of a "guitar guy" than a "computer guy." If needed I can make screencaps of my parameters.
JP
Intel Quad Core Q9550@2.83 GHz
4.0mb RAM
ATI Radeon 4800 Series
JP
4.0mb RAM
