crazyhorse
Someone recently gave me the run down on using a compressor to enhance tracks when mixing a song and I would like some other opinions.
My friend said that he compresses each track so that the wave looks flat (squarewavish) instead of peaky (sawtoothish) before normalization and mixdown. He says that by doing this and normalizing everything to just below clipping you can get the maximum 'hot' signal in the final mix.
How much is too much compression? What instruments should you use the most on? How about for techno/dance music vs. standard rock quartet setting? What are some good software programs being used?
He said that he talked to someone who switched from analog compressors to digital for their ease of use and transparency. I thought that highend tube compressors were one of the great secrets to getting that warm 'pro studio' type sound, especially on vocals. I am thinking of using my Johnson Millenium 150 amp which combines a tube pre-amp with S-disc fx processing (as well as compression) to run a SM-57 (all I have) to get that type of sound. The amp has direct XLRs out so I wouldn't be relying on the inefficient amp cones for sound, just whatever the processor could pull off.
I don't own a bass so I'm also thinking of pitch shifting my guitar through the Johnson to get a bass sound. It sounds crappy through the cones but I haven't checked the XLR outs yet to see how much low freq. the processor is actually pushing. But that's a whole other deal...
Please help me out on the compression questions! I am so close to getting a good mix!
