guitarfreak12 said:
now what about miking. Should I get the pastor lavied up and the bride and groom should come out ok on that too, or something else. I've got all kinds of LDC's, SDC's and lavaliers.
Yeah, lav on the minister can be good. Don't count on that to pick up the bride and groom with that, though. You *might* be able to get away with a wireless lav on the groom, but don't count on being able to clip one on the wedding gown
Other options include setting the minister up with a decent cardioid on a mic stand. Either set the stand up with a T that would allow you to have one mic facing the minister and one facing the condemmed...er...happy couple. Or have the minister with a lav and set up a small hypercardioid on a small floor stand at the pastor's feet facing up towards the couple.
A third strategy that can sometimes work depending on your camera setup and the church layout would go like this (I've done this before to quite decent results.) On my 3-camera setup I had two handhelds (sometimes mounted on homemade steadycams) with the third camera set up unmanned on a tripod at the back of the altar, a few feet off the centerline and pointing back towards the bride and groom. This camera would be pre-zoomed to get a good look at the couple as they are facing the minister without having to have a distracting cameraman wandering around in everybody's field of view. If the altar is shallow enough (it's not Notre Dame
) or you can get an unobtrusive camera position close enough (like 15' or so), mount a decent shotgun mic on the camera to get the bride and groom and just record that shotgun to the videotape. The lav on the minister will go to the mixer. Then just mix that all in with the rest of your audio during the vows.
Ambient room mics can be used, but frankly aren't really necessary. All you need is the minister, bride/groom and father of the bride. Also you'll need to mic (or tap off the church FOH) any singers/musicians/podium speakers during the ceremony.
If they are playing any recorded music during the ceremony (which is fairly common, at least around these parts), get the playlist ahead of time from whoever you're working with in the bridal party and get legal copies of those WAVs or MP3s for yourself to overdub into the soundtrack during post. It'll sound a hell of a lot better than tapping off the FOH and depending on that guy's levels and sound.
EDIT: Oh yeah, often times the FOH provides the minister with a handheld mic for feeding the PA. Usually if you just tap that off the FOH, you don't even need to mic the minister.
G.
