If you like the sound of a full 100% preamp tube,.... .... that is what other types are measuered from.....
the 12AX7 is the one,..... highest gain from any preamp tube,....
at least from current amp designs,....
after that you can vary the flavor a bit by making it different,...WA, or WT,.. or any of several designations from different manufacturers....
The others are 12AU7,12AT7,12AY7,12AV7,12AZ7, 12DT7,12df7, 5751, 7025,6057,6681,7729,6L13, B339, B759, E83CC, ECC83, M8137,.......and yet many others that would work,..... such as the 12DW7, it is actually an AU, and an AX in the same bottle...
In a single ended low wattage tube amp the usual circuits that are used, use only 1/2 of the tube for the preamp stage anyway,... and the other half on the power stage,...
How you achieve your 'PERFECT' tone is up to you,....
Read your manual, and ask a tech to be sure, but usually there is no problems with the sort of amp you have,.....does it have a solid state rectifier stage???
If so, you should be sure to use the standby switch, it turns on the heaters in the tubes to warm them up before full power is put to them,... that happens when you go from standby, to full ON...
If your amp does not have a standby switch,.... be sure to warm up the amp when you move it in cold weather,..... otherwise,.... you will, at the VERY least shorten the life of the tubes,....
find somewhere to try some used tubes to get some idea of different sounds,..just by putting a different type or brand in that Pre slot....
the power tube on a single ended, usually can be changed to the same numbered tube with no dire results, but that tube is sometimes not for an inexperienced person to mess with,..... that should be researched for your own amp,.... it is different for an A/B amp as it is very important to have them balanced in those designs,... Push/Pull,......
if the experimenting is not an option for you,.... I would suggest any (I prefer NOS RCA) brand of 5751,... it has tons of tone,....only about 70% of the gain of a 12AX7,... are built VERY rugged as they were designed for military applications,.....
If it can be dropped from a plane, sort of ruggedness,.....I think it would be OK in most any amp.....
GE has a nice tone too,... a bit brighter,... but in my single ended amp it is a bit piercing so I like the RCA,.... better mids and a little darker sounding,.... ringing highs,.. but not piercing,.... find one, and Eme, I will send you a brand new GT12AX7WA and you will hear the difference a cheap russian tube will sound like....you can keep the GT,......Sovtek,.....as a backup.......
Steve
the above is only an opinion, and your safety cannot be guaranteed if you do not seek professional help with any major modifications,...especially when it pertains to your attitude,.....
so put down the dube, splif,blunt,bud,........put,.... and be safe......
THE ABOVE MESSAGE IS BROUGHT TO YOU BY<<<<<<<<<<<>>>>>>>>>>
you know,.......
them.........
<<<<<<<<<, over there<<<<<<<<
Yup, Knowing that ,.... how could you even,......
