John Sayers Solar Power!! Jan 10, 2004 #2 Good in that it can handle the spl good in that it has a tight pattern - keeps other sounds out. good in that it has a slight high end lift built in only problem is the rolloff in the low end but that can be compensated for. cheers JOhn
D dumass New member Jan 20, 2004 #3 at thelisteningsessions.com i saw them using it, and it didnt sound too bad to me...
N nascentjunkie New member Jan 30, 2004 #4 i used one... i used one a long time ago before i had a real kick drum mic, but now that i have used the d112 i won't go back to the 57.
Track Rat Just Your Average Sized Member Jan 30, 2004 #5 Not the first mic I'd reach for but it can definately work there. A lot depends on the particular kick you're miking.
Jblount New member Feb 5, 2004 #6 You can slap a 57 infront of about anything and get a sound you can work with.
