Bobby Darko
Hey guys,
I thought I was there. My two Tascam 688's sync up nicely with the midiizer(although it's a bummer I have to stripe them seperately), they lock up, play, rew, ffw etc. The master recorder records, but the slave won't. When I press rec/play on the midiizer it just stops after a second. This is one big problem, cuz I have a job this weekend.
Problem numero dos:
The musicians and me need to monitor the tracks from both recorders at once. I used monitor out to dual in, monitor ou to aux in and every other combination I could come up with. The cable is fine, but there's a lot of humming happeing on the monitor mix. It pretty damn hard! Maybe I should get the behringer mon800?? I guess that would be fine for monitoring, but for mixing down?
Hope you guys have any clues or tips! Much appreciated. Hermann (fna Bobby)
Problem numero dos:
