Connectors
shackrock said:
i asked all this to the "radio shack technition" and (yes i know, he was also doing a sales job on me..ha...BUT) he said that any time you add a connection (hence an adapter), you will lose quality. Depending on the adapter, the and all the stuff you have already, it will decide how much quality is lost.
however, all those radio shack xlr-1/4" CHORDS.(NOT adapters) he said would be great if thats what you needed because they are sodered etc. all right in the chord....he's a good salesman, i bought it..ha
Do not listen to anything a Radio Shack salesman says. Just don't do it. Okay, I'll admit he might be right. But taking a wild guess might be right, too.
Did he really say that there's a difference between:
Code:
- using an adapter: cable-XLR -> XLR------1/4plug -> 1/4jack
- using a cord: cable-XLR -> XLR-cord-1/4plug -> 1/4jack
because of the way they're soldered? That's just crazy. There
might be some vague mechanical advantage in some applications, where you could let the cord drape over something that supports it to avoid straining a jack, but that depends on other things and has nothing to do with how anything is soldered.
The notion that "any time you add an adapter" you lose "quality" is nonsense. What is the mechanism that makes the "quality" leak out?
Yes, any time you add an adapter, you increase the potential for a problem ... that is, you introduce a place where a connection may go bad every once in awhile. A connection that goes bad usually will manifest itself with an obvious "loss of quality," like the sudden introduction of silence, or buzzing, or some obvious distortion.
The use of an XLR-1/4" adapter is a whole 'nother subject, and one that goes beyond the general issue of adapters. Generally, if you use an XLR-TRS adapter, and insert the TRS plug into a TRS jack, you should wind up in about the same place you would have if you'd just put the XLR into an XLR. If, on the other hand, you use an XLR-TS adapter, or plug a TRS plug into a TS jack, you might (or might not) do something bad. It isn't a matter of adapters being bad in general, it's a matter of disconnecting (or grounding) one of your lines.
A somewhat different issue: if you use an XLR-1/4" adapter to hook a microphone to a 1/4" input that's looking for a high-Z line-level input, you may also have a problem ... the adapter didn't create the problem, though it did make it easier for you to create the problem.
