The main reason that MP3s are like that is because that is part of what the MP3 compression encoding process does itself, not because the engineer does that on the master. Even if you have a lot of stuff above 15k, most of it will be removed in turning it into MP3 anyway.I have read online that I should by hi-cutting my mix at 15-16,000hz during mastering and after spectrally analysing a few mp3 this seems to be common place. What is the point of this and is it recomended?
Except the howling dog next door .Try a high pass filter at 15hz. It will remove all your problems!
Watch the spectral view. If there is nothing unusual at high frequencies, then there is no need to filter.Plus I heard this thing on the news a while ago that teenagers have a better hearing at very high freqencies than older people and I thought It might be for them, I think i'll leave them in though, thanks again.
Should I Hi-Cut My Mix At 15000hz?
