Josh83 said:
I am shopping for a laptop and, while audio won't be the PRIMARY use, I plan on using it for audio eventually.
However, I don't want to get into always needing an external hard-drive to record.
So, my question is: recording at 24/96, how many tracks of playback will likely be my limit with a 5400 hard drive vs. a 7200?
I am between a few PCs and an Apple Powerbook, and I don't know what to get. In either case, Tracktion will be my software, and in either case I will have 2G RAM.
Josh
I'm currently looking at getting a laptop myself Josh. When I first started my first choice was Toshiba. Toshiba really makes some top of the line laptops, they are light, and they do not over heat. However, I'm thinking of going with Alienware. I still have to look at reviews for Alienware, but I really liked what I saw at their website.
To me the fact that Alienware will sell you the laptop with a 410 Firewire and Sonar 4 or Cubase means that they have tested these components and you will not have any issues. In addition, you have the option of choosing a 7200 rpm HD (internal) and an additional HD (7200 if you desire). The only drawback to Alienware is $$$. Dell's are pretty inexpensive laptops and good enough for the price.
My recommendation is go with the most memory and the fastest processor you can. Then if you can afford the 7200 rpm HD go for that. However, 90% of your performance will come from your processor & memory. I know Professional Studios with computers that have 1GB of RAM, 2.8GHz and 5400 rpm hard drives. They have no clipping, no issues, no latency. Granted this is with a home built. Still recording 24 tracks at one time (granted at 48K - otherwise he has problems) without issues.
IMHO the processor & RAM will give you problems way before the HD will ever give you problems.
See, think of your hard drive as the engine of your car. Say your car engine can go at 1,000 MPH but your injectors and your fuel pump can't handle the rate of fuel consumption by your engine at the higher speeds. Then what's the point in having an engine that can do 1,000? Your injectors and your fuel pump are you RAM & your processor. The faster the RAM & Processor the better you'll do with a 7200 or 10,000rpm HD.
Anyway, hope all that helped.
