NRS said:
I'm a still a bit confused by what you refer to as the mere "coloration of frequencies" vs. the real ability to actually flatten the sound with EQ though.
There are several issues involved, a few of which Noisewreck and MSHilarious already hit upon. But to answer the above question directly:
First, even if you go with a full 1/3rd octave graphic EQ (31 bands), the resolution is still not necessarily fine enough and the center frequencies of each ban not necessarily targeted enough to be able to "flatten" the room response. For an example pulled out of a hat, you might be sitting in a null at 280Hz that's only 20Hz wide. With the nearest bands at 250 and 315Hz, you couldn't target that null at all. And even if the null were right on 250Hz, the bandwidth of the EQ band is not going to match the bandwidth of the null; you'll be artifically boosting a lot of surrounding frequencies just to try and pull that null out of the hole. It's like a bubble under plastic; flatten it here and it pops back up elsewhere.
With a parametric you might be able to attack that null, but there are a limited number of frequencies that you can attack with a parametric EQ because there's going to be a limited number of bands of EQ available to you. Still no flattening of the response at hand.
Second, and perhaps most important, things like bass and midrange nodes in room response are properties of the room, and not of the playback system. Trying to attack them with EQ will have little to no effect because the modes will still be there. Think of them as room resonances (which is what they really are.) There will be some frequencies that at certain locations in the room - including potentially your monitoring position - just will not reproduce or will reproduce too well, regardless of your attempts to EQ them out. And in another form of that plastic bubble analogy, if you do manage to even out a given trough in the room resonance, you are boosting way out of line that same frequency in the nearby resonant crest, which can sometimes be a matter of inches away. Move your head 6 inces to one side or another and all of a sudden your "flat" rsponse is honking out at you like a French ambulance siren
Your heart and mind are in the right place, but the "fix" you have in mind just won't work quite the way you think it will. Many have been down that path before you; you might get a mix to sound good in that room, but chances are far better than not that it just won't translate well to the outside world.
Room treatment doesn't necessarily have to be expensive. There are lots of homebrew solutions that can work great; sometimes just moving a piece of furniture a bit can make all the difference in the world. Other times a quick trip to Home Depot for some Owens Corning fiberglass or a cheapo bookshelf, nether of which will cost much at all, can give you just what you need to get your room manageable.
Finally, I'd think hard about the idea of "mobile mastering". "Mastering" is something that should be done under at least understood - and preferably controlled - acoustic curcumstances. Taking a laptop to an unknown room to master a production is like taking a patient into an unknown room to perform surgery; either way you have no idea how your patient will become contaminated
If you're just hobbying around, then that's a differet story. But then again if your just hobbying around, you probably wouldn't bother spending money on accurate acoustic measurement gear
. And hobby or pro, the acoustic properties of the room still cannot be very well addressed via monitoring chain EQ.
G.
