undergroundtoon
WELL I AM STUMPED!!. I have a Toshiba Satellite 1.7ghz 2gb ram. I got a saffire le last week to hook up to this as a portable studio. I have tried 3 different pcmcia cards with no luck. The focusrite flashes on and off (my cpu usage flashes from 0 to 100%) every 3 seconds when plugged into the laptop. I have installed and uninstaled the le driver 3 times. Two of the 3 pcmcia cards were windows recognized and the third had a driver to install. I have run the device manager and my slot is working fine. The card and saffire both give a bink bloom sound(windows rec) when i plug them in or unplug them. I also un installed the driver for that one card that came with one(disk driver).
I set this up on my home pc just fine? I was recording on aduacity in 10 min total time. The saffire is pluged into the wall, So its not like i am using the 6 pin for power. On one of the cards i went and spent $20 on a power convertor (thinking it might help give a little more juice)with no luck. It may work great on my home pc but i already have a Tascam FW 1082 for Home PC recording. Its not like i was buying cheap fire wire cards either the 3 ranged from $40-$80.
I was thinking it was a problem with the 6 pin since the 2 add current(but it works fine on the home pc with 6 pin?). Would a 4 pin card and cable solve my problem(i doubt it) since its plugged in and working on my home pc already? I also tried installing the *firewire cable only* and the *firewire conected to the pcmcia card* in the laptop at the point of the install that says "Plug in your Saffire le now and hit continue". I HAVE HEARD OF PEOPLE SPENDING $10 ON THEIR CARD AND IT WORKS FINE! Maby my card choice is bad thou and help would be appriciated. Thanks. I searched the internet(including the focusrite site) and on here looking for a "RECOMENDED for the SAFFIRE LE" card with no luck. Is their a setting i am missing?
