fountaincoolguy
roland vs840gx 8 track digital recorder for sale (no manual)cant find one for it therefore must sell make offer to fountaincoolguy@yahoo.com
• Digital Recorder
• Number of Tracks: 64 (8 tracks x 8 V-tracks); 8 tracks max. simultaneous playback; 4 tracks max. simultaneous recording.
• Max. Usable Disk Capacity: 250 MB
• Recording Mode: Multitrack 1 (MT1), Multitrack 2 (MT2), Live 1 (LV1), Live 2 (LV2)
• Sample Rate: 44.1 kHz, 32.0 kHz, Sample rate can be adjusted between 24.05 kHz to 50.46 kHz by using vari-pitch function.
• Synchronization Master: MIDI Time Code, MIDI Machine Control, Song Position Pointer + MIDI Clock (SYNC Track Mode, Tempo Map)
• Slave MIDI Machine Control
• Interface for Storage Medium Internal 250MB Zip Drive
• Digital Mixer
• Channel 8 (12 at Mixdown Mode)
• Equalizer 3-band EQ x 8
• Common
• Signal Processing Internal: 24-bit (mixer section), AD Conversion: 20-bit 64 times oversampling,
• DA Conversion 20-bit 128 times oversampling
• Sample Rate 44.1 kHz, 32.0 kHz
• Frequency Response Sample Rate 44.1 kHz: 20 Hz to 21.0 kHz (+1/-1.5 dB) 32.0 kHz: 20 Hz to 15.5 kHz (+1/-1.5 dB)
• Total Harmonic Distortion 0.08 % or less (Input Sens = -10 dBu, 1 kHz at nominal output level, recording mode: MT1)
• Nominal Input Level - 50 to + 4 dBu
• Input Impedance INPUT 1 (Guitar(Hi-Z) type): 1 M½, INPUT 1 to 4 (1/4 in. phone type): 20 k½, INPUT 3 to 4 (RCA type): 20 k½
• Nominal Output Level Monitor/AUX: -10 dBu, Master Out: -10 dBu
• Output Impedance Monitor/AUX: 1.6 k½, Master Out: 1.6 k½, Phones: 100 ½
• Recommended Load Impedance Monitor/AUX: 20k½ or greater, Master Out: 20k½ or greater, Phones: 8 to 50½
• Residual Noise Level Monitor/AUX: -91 dBu or less, Master Out: -91 dBu or less (input terminated with 1 k½, Input Sens: +4 dBu, IHF-A, typ.)
• Effects Algorithms: 32, Preset Patches:250, User Patches: 200
• Display: 69 x 25 mm Custom backlit graphic LCD
• Connectors: Digital Outputs (S/PDIF Coaxial, Optical), Analog Inputs (1/4 in. x 5, RCA x 2), Monitor/AUX Outputs (RCA x 2), Master Outputs (RCA x 2), MIDI (IN, OUT), Phones (Stereo 1/4"), Footswitch
• Power Supply AC117V/230V/240V
• Power Consumption 20W
• Dimensions: 16-3/16 x 12-1/8 x 3-1/2 in.
• Weight: 9 lbs. 15 oz.
• Accessory: Demo Disk
• Options: VS4S1 VS840 SCSI Board for data backup on external Zip drive and hard drive.
• Digital Recorder
• Digital Mixer
• Common
