SouthSIDE Glen
independentrecording.net
True, but remember that the "center" of the loudspeaker driver is the voice coil area, the circle *around* the dustcap. That's where you'll usually be getting the best and most accurate highs. Anything coming off the dustcap is truely incedental.peritus said:Yeah.... The thinking behind using the 421 as the innermost mic was the idea that the center produces the highs..
That said, that doesn't mean that you'e can't get the sound you want off the dustcap. But I'd try other options as well. There are dozens of different ways to mic a git cab; and what works best for any given session depends upon a long chain of variables from the player style, to the song arrangement, to the guitar/pickup type, to the cab model, to the mic pres used, etc. The implication from your OP is that you have one main recipe for miking the cab. My best recommendation is to open yourself up and tray a whole boatload of positioning options. Take a day and expiriment not only with placement, but with angles as well. Try some ither mics while you're at it. The 57 and the 421 are classic go-tos, no question. But so are Big Macs; and most people would not want to eat a Big Mac for every meal every day of the week.
Probably the easiest solution, if you're worried about phasing, is to use a single microphone. A single 57 or or 421 *placed with care* can sound better than a combo of the two placed just ad hoc. Especially if you're going to double the parts anyway. Record one track with the 57 and the other with the 421, both of them placed with attention to detail, and you can often get a much more textured sound than you can with doubled tracks that are sonically identical.
Mix it up before you mix it down .
G.
