sizzlemeister
The question was raised last month at Music Player (and recently cross-posted here). Despite a lot of digging and reading I really haven't found much information on the differences other than little bits here and there.
The R-factor of rigid insulation is significantly lower than the R-factor of fluffy on average, and the cost is about triple to quadruple. Now, as I've come to understand it, the greater the R-factor, the greater the dampening effect insulation has as a general rule (due to density).
While rigid has consistent density throughout its plane and does not require support, its expensive, hard to obtain, low in R-value, and isn't very malleable.
Fluffy has greater R-values, is easy and cheap to obtain, can be made to fit nearly any structure and can be stacked to increase density.
Am I missing something here? Why use rigid over fluffy in sound-proofing applications? Why is rigid, like, "all the rage" and people are going to great lengths to get 703?
