Hi Rick,
Just a note
I own
a CAD Trion 7000. I bought it at Christian Music Summit last year because I heard how it sounded, was able to compare it to other mics, including several hi-end condensers, and recognized its silky-smooth response and breathiness, just with my voice. It's a new design, but still a classic figure-eight dual-element ribbon. Phantom power will destroy it.
I can't emphasize how important it is to actually _hear_ a mic, provided you have a good understanding of the gear it's plugged into, settings, and monitors. Everything should be a flat response for judging how a mic itself sounds.
The reason I got it was mainly for wind instrument close-ensemble work, i.e., where musicians play in a semi-circle so they can hear each other for extremely tight timing and intonation without the encumbrance of headsets.
I've used it on stage, but haven't had a chance to make any actual recordings yet ... my new studio won't open until Saturday, and even then, only unofficially.
The plan is to use it together with a cardioid condenser and two room ambience mics in a Mid-Side stereo combination (if you need more on MS stereo coding, let me know). I expect to use an outboard pre with plenty of gain and impedence-matching and with no phantom power on the ribbon, and let the board pres push in the condensers, with a wee bit of stereo compression plus some narrow band graphic EQ -driven sidechain compression just in case I have to gate noise I don't like. I expect to be mastering this stuff someday, so I don't want to get in the habit of leaving myself a bunch of extra downsteam work.
HTH,
Ken N.
