Yeah this could be. I was thinking rocking it on the front feet. Maybe that's not enough.I used to own an old Peavey and the sound that he's talking about requires a heavy shock to produce.
Here you go, unstrap the tank from the amp, bounce away.
You know I have no reason to doubt the 'don't move the amp till the tubes cool' thing, at the same time, I have to wonder with the 110+db vibration hours on end going on back there.
I am doing a theater gig. One song, they needed some "thunder" and I crank up the reverb on this old crap peavey classic I am using and bump it until it goes "KERANG!"
What is the risk of damage?
This amp is the old SS pre and tube power amp. Where is going to be the point of failure? I thought it was making a kind of weird noise after about the 6th time I did it. I am considering not doing it, but it just sounds so freaking awesome.
Add it to the drum kit with a beater.Totally awesome effect for dub reggae. You could even do it live.. Just pound the goddamn thing with your fist on the one...
That's just the reverb tank springs bumping around. But the opamp circuitry it's connected to amplifies it so much, you get a horrendous crash. Even gently knocking those springs together will create an explosion of sound.
Physically there is little or no chance of damage to the reverb tank or springs. This page shows what's inside:
http://sound.westhost.com/articles/reverb.htm
So imagine what you would have to do to shake that tank to the point where the springs break. In practice, you probably couldn't even if you tried. If it did break, it would probably be a simple matter of unscrewing it and hooking the springs back on to what whatever they are supposed to be clipped to.
I am doing a theater gig. One song, they needed some "thunder" and I crank up the reverb on this old crap peavey classic I am using and bump it until it goes "KERANG!".
