F
FUNKY
You must have known reading the threads that I've bought Aardvark's 24/96 Directpro card..
Finally , after 3 night without sleeping I got some tips for better functioning and wiring of the card..
What did I find out?
1. the noise in the speakers resulted from the "heavy" output gain which creates the noise..I think that that is the common problem of everyone using Aardvark card with active monitors..Let say, I run my Dynaudio's on +4dB mode and when I chaned it into -10dB the noise was bigger..
What did i do? I decided to run the Aardvark output signal thru my Spiritfolio mixer and then in the channel , have set a higest gain and the lowered down the monitoring fader of the mixer..What happened? The signal was still loud and the noise dissapeared..I think that most of the Aardvark users have this problem
2. Problem with the preamps when recording vocals..
Aardvark has three levels of input's setting..First, the line out setting, then "Mic1" for normal miking and "Mic2" for "silent" microphones..When I wanted to record in "Mic1" technique noticed that the input gain goes between +33 to +52dB which was "peaking" mosto of the time.."MIc2 is set between +50 to +70dB..brrrr...And Line mode went between -14 to +10dB which was acceptable..
Cause I had no solution how to lower down the input gain of the mic, my only solution was to run my RODE thru the Folio mixer and then to re-route it vie line in of the input1. Then I could regulate the volume and input gain of the mic..
Correct me if I'm wrong..
3. My problem these days is the monitoring..
I have a breakout bow which is using the headphone's out and then it spreads the signal to use for 4 headphones( i think you know it ) I use this for singer's monitoring...
But..
The trouble is that the monitoring is poor..I dont hear it loud like I want to ...and can make some balance between the music and the voice ( when the singler sings)..He complains that he is not hearing his voice well and that the music is covering him..
I tried everything with the settings and found out that he hears good when I turn up his fader up, but then It peaks and don;t know what to do?
Can anyone help me with this "monitoring problem"???
Thanx guys
Will give you more info of Aardvark's card
FUNKY
((((Correct me if I'm wrong..
But..
Thanx guys
FUNKY
