the key deck nneds to be3 out of the chassi... ya want to approach the thing kinda sideways cause you grab that finn on the pivot end and pull up and forward slightly... at the sametime pull the font of the key up and back... and no big hammers.... if ya look at the one on either end youll see there's a spring set in there... so watch it... and the spring has to load into the key putting it back together.... good luck... and be careful with the grease... dont know if thet changed it but it used 3types of grease for the three pivot points... and the get nasty thick if mixed... if there's crap in the grease just remove with a Qtip...
