C
Chrisjob
I have a Soundcraft Spirit Folio F1 (16-channel) mixer that I use mainly for routing inputs. The main outputs which respond to the Master Mix faders (xlr) are starting to short. I'd say the right channel works about 60% of the time, and today, the left channel started to crackle.
If you really cranked up the gain you can hear a faint signal. I'm 95% sure the problem is with the XLR outputs. I've checked the cables, and everything sounds fine with headphones.
Is this something worth trying to fix? I quite like this mixer, and don't anticipate needing to upgrade anytime, as it suits my needs well. I have minimal soldering skills. Can I locate the problem with a multi-meter? Would contact spray make any difference?
If I were to get it fixed, whom does one contact for this kind of work? There are some service centers listed on Soundcraft's website. Are these the best options?
Thanks and cheers,
Chris
Thanks and cheers,
Chris
