Sifunkle
Possibly my newbest question yet, and I might know the answer anyway, but I want to be sure.
I've done a lot of reading on 'music production for beginners' recently, and it seems like every author has skipped over this, possibly because it's so fundamental it's assumed knowledge... but: what is a stereo track?
I'm coming from the angle of having only recorded one thing at a time through my interface (one mic, one instrument line, etc), which I expect partly explains my lack of understanding...
I know what it looks like when I have one in Cubase: kinda like one track that actually has 2 tracks in it. I assume they get sent through Lines Out so that one goes to the L speaker, one goes to the R, and so forth. But given that you can pan mono tracks towards the L or R anyway, what advantages do stereo tracks have?
And how do you create them in the first place? I mean I can set up my single condenser mic so that it records to a stereo track instead of a mono, but what's the point if the two parts of the stereo track are exact duplicates?
I'm assuming stereo tracks are for when simultaneously using, eg, 2 mics at once to record the same thing. For example (maybe not a realistic one), you could put two mics either side of a singer and record some vox into a stereo track, so that you'd have the mic on the L picking up the ambient characteristics of the L side of the room (and the stereo track thus causing that part of the recording to come out the L speaker) and the same for the right mic. But even then, I dunno why you'd favour that over 2 mono tracks, which you could do the same thing with anyway, among many other things.
I can see that perhaps if you were recording say a live band, you might want to use stereo tracks in order to preserve the spatial arrangement of the band (having the bleed from other performers than the one you were micing coming from the correct side). From my brainstorming thus far, this scenario seems to be the only one where stereo tracks would be better suited than mono...
Could someone please:
- Confirm my impression of what a stereo track is?
- Comment on my suggestions of what stereo tracks might be used for?
- Suggest applications where stereo tracks would be favoured over mono?
Thanks in advance!!
Si
Thanks in advance!!
Si
