Mike Freze
I have a lot of hardware effects processors (foot medals, mainly) for guitar/bass/mics. Old habit from the live playing days, I guess.
If you record in a small or medium-sized room and you want a good crank our of your guitar or bass without blasting your ears out in the room, is using a pickup booster effects pedal a good way to go? I have one designed for guitar or bass. Will that help keep you from having to crank your amp up too high for a "hot signal" and not go over that recording threshhold that causes distorion/clipping?
Or are pickup boosters only good for making your guitar itself sound hotter (or better) when you only have the stock pickups that came with the guitar when you bought it and haven't replaced them with better quality pickups?
If anyone has messed around with pickup boosters like I have, I'd appreciate advice on how you use them to get that great boost effect (hotter guitar tone or hotter amp signal) without clipping when recording in a small environment. I use a Fender twin reverb, tube amp (2 12" speakers). I also have a solid state Crate amp/speaker system, if it really matters which one I should use concerning pickup boosters.
Oh: Does a booster only help if you have great pickups to begin with or will they help stock pickups to sound better too??
Mike Freze
Mike Freze
