Modern_Talking
hi guys .. I' hope I'm in the right forum .. if not, please do move it to the right place ..
here's my setup .
Behringer mx 9000 mixer
Fostex VF160ex H.Disk
Lexicon MPX1 effect (sub group insert 3&4)
T.C Electronics effect unit (sub group insert 5&6)
31 band E.Q (sub group insert 1&2)
2ch Compressor (sub group insert 7&8)
Yamaha Motif ES Rack module (Assign L/R, 1,2,3 & 4)
Roland JV 1010 module (Assign L/R)
Events 20/20 monitors
AKG Headphoes
Main Insert ch's on MX 9000 = Aphex 204 Aural Exciter
Sub 1 & 2 Insert ch's = 31 Band E.Q
Sub 3 & 4 Insert ch's = Lexicon MPX1 effect unit
Sub 5 & 6 T.C Elect. effect unit
Sub 7 & 8 Art Compressor
Now, as you can see above, that's the way I've connected my effects and compressors etc to the MX 9000 mixer ... I have not connected my Fostex vf160ex yet ... This is where I'm lost ...
On my MX 9000 mixer's input ch I have used up the 1st 6 inputs for the Motif EX rack. Meaning, on the Motif the L=ch 1, R=ch2, Assign 1=ch3 ...., Assign 4=ch6... On the JV 1010 it's L=ch7 and R=ch8 ..
I am using Cakewalk 9 as my sequencing software and I am doing mostly MIDI tracks..
Now I've done all my balancing and everything sounds great on the headphones and on the monitors.. But the problem is that everything is coming out of the MX 9000 is in 2 ch (stereo) (I mean the main outs from the board)...
I want to record the above channels individually into my Fostex hard disk recorder.. But if I pull out the input cables form the mixer and connect them to the input channels on the fostex recorder, I loose my effects and eq's and compressions and all the setting that I tweeked on the mixing board, since it's now not going thorugh the mixing board but straight from the module to the hard disk recorder.
And yes, I have individual channels assigned from the sound modules (as indicated above) to the mixing board... I tried using the direct out on the mixing board which helped but theere was no effects or eq's etc. The signal was dry .. I guess that's why it's called direct out .. heheheh!! lol..
So, can anyone tell me, how it is possible, to route my individual tracks from the mixer with all the effects and eq's I hear from the Main Outs, into separate outs, into the hard disk recorder for individual channel recording.
Remember, I am using my Sub outs on the mixer which have effects connected to the insert channels... This way some channel (eg ch 4,5) I don't want any effect but the rest of the effects (compression & E.Q) I would like to have.
I hope I explained myself clearly and someone could give me some suggestion in getting this thing to work this way .... I have everything well balanced and sounding great, but don't want to just take the 2 stereo outs form the mixing board and connect it to the hard disk recorder ... Then I'd have everything going to 2 tracks only and later on if I want to cut out any instrument, I won't be able to do that ... That's why i wanted to record them individually ...
thanks for taking the time to read this and your help or suggestion is greatly appreciated ...
peace ..
here's my setup .
AKG Headphoes
peace ..
