Re: recording a live drum set
GRADSTANG said:
forget the drum triggers the brain is way too expensive approx how many mikes would it require to record about 4 cymbals and 1 high hat
1 condenser directly over the drummer's head for mono, and preferably a matched pair of condensers for a stereo recording.
You can make decent quality recordings of a drumkit with 2 to 4 mic's.
For a mono image of the drumkit with 2 mic's:
1 mic on the kick.
1 overhead. (I like to put this about 12"-24" above the drummers head, and aimed straight down at his head.)
Suggested Mic's:
Kick: AKG D112, AT pro25, or an ATM 25 (The pro25 is around $80)
Overhead: MXL603 (goes for around $80)
For a mono image of the drumkit with 3 mic's:
1 mic on the kick.
1 mic on the snare.
Suggested Mic's:
Snare, SM57 , or Beyer M422 (The 57 is around $80)
For a stereo image with 3 Mic's
1 mic on the kick.
2 overheads. (You'll have to experiment with placement, but I like them behind the drummer, rather than in front of the drummer, because it helps eliminate any sound from the wall behind the drummer.)
Suggested Mic's:
Overhead: MXL603 (around $80 each)
For a stereo Image with 4 mic's:
1 mic on the kick.
1 mic on the snare.
Suggested Mic's:
The key to this kind of recording is that the drumkit HAS to be well tuned, and the drummer has to be able to play well dynamically.(i.e., not hitting the hihat harder than the snare.)
Tim
