geneticfunk
I have a few questions about mixing audio, I'm wondering if anyone can recommend a good tutorial(s).
For example, one question that I have is: Consider two different sets of mixer volume settings for a given project. Assume that there are no effects being used, and that we're only working with audio (no MIDI). Now, assume that for either configuration, the amplitude of the signal leaving the output bus is the same. In Configuration A, the track mixer volume settings are pretty close to the bottom of the sliders, and the output bus mixer volume setting is set to zero (NOT -infinity). In Configuration B, the track mixer volume settings are set to zero, and the output bus mixer volume setting is set pretty close to the bottom of the slider.
Will there be any difference in audio quality between Configuration A and Configuration B?
Anyway, these are the types of questions I'm wondering about. If anyone can recommend a good tutorial(s) or even just answer my question, i'd appreciate it very much =)
