Hi!
I have a little issue I need some guidance with, I need a decent soundcard that I can use when producing music.
Just an example (I can't explain it better): if you want to play hd-movies on your PC you need a graphic card that can decode the hd-video = hardware decoding, if your card can't play hd-movies the CPU will decode the video.
I need a soundcard that can decode the sound by itself i.e. the sound processor decodes the sound, not decoded by the CPU etc. Just as the example above but a soundcard instead of the graphic card example.
I don't know what the feature I need is called but I think it's called ASIO, and I don't know how to check if the soundcards has this feature.
I am going to use the card when I produce music in FL Studio and Cubase so ASIO is important.
So, guys, what soundcard brand/model do you use? And what can you recommend me?
Currently now the soundcard in my PC is a Creative X-Fi Fatal1ty Champion (SB0460) and I think I need a better card for producing, also this is a PCI card and i would rather have a PCI-E card.
I can't spend a fortune on the card, maximum price is ~220$ (~175€)
Hope I can get as many replies as possible
Thanks //YBWM
Thanks //YBWM
