Not much help here but only insight...
Unfortunately latency is caused by a big buffer where the CPU only gets a little data at a time to process if there are other things going on in the system concurrently. In the other hand if not enough buffer is set, then you get pops and crackles. This happens no mater which DAW you use. Most importantly to consider is how many plugins are being used as well to process sound data. So a balance is key, however to achieve that balance is a mater of system setup.
