Hi, I am new to reamping and I wanted to ask your advise.
I own a passive reamping box (Radial ProRMP), and I wanted to reamp some direct signal I recorded some time ago. If I send the signal straight from my sound card to the amp it makes a lot of background noise, and I know that's expected since (as far as I understood) the output of the sound card is balanced. Then I tried using the Radial in between, and the background noise has got only so much better, the signal seems far from clean as it should be. I must maybe say that the direct signal was not recorded with a direct box (so I recorded it unbalanced), but I don't think that's the real issue, since the background noise is present at all times, not only when a track is playing.
Am I doing something wrong in the connection?
Thanks a lot!
Thanks a lot!
