hnia6
Member
This is baffling the hell out of me. Here's what I'm doing:
I'm re-amping using my TASCAM US-1800. Not counting the monitor outputs, I have four (2 pairs) balanced TRS analog line out jacks (numbered 1 thorugh 4) in the back. There are no other outputs.
I only get sound out of line 2. I don't understand why, but my bigger problem is coming below. My manual states the normal output is +4 dBu and to connect these outputs to an external mixer, recorder or other device.
I'm going from line 2 through my Radial ProAmp passive box, through my effects and into my Fender Deluxe Reverb. I can hear my previously recorded DI dry track through the amp. Not quite as nice as the guitar live, but good.
I have a two mics placed in front of the speaker at ordinary locations - used for live recording with no problems. One's a dynamic. One's a condenser. The phantom power is not used on the dynamic.
I am recording through Cubase Artist 6.
Here's the problem:
I can't get either mic above -24 on my level (about half way to zero) on either mic channel without terrible feedback starting. I can make the amp louder but then the levels need to go lower. I played with the gain setting on the ReAmp box, tried each mic seperately, moved the mics away from the amp some - didn't matter.
My suspicion is that it has to do with the TASCAM output. I had the exact same problem trying to use my Radial DI backwards as per it's manual.
Can anyone PLEASE help me figure this out? I want to record at the same levels as live recording.
Thank you in advance!
Here's the problem:
