rightbrainnow
ok so today i did extensive experimentation with mic placement on electric guitar. i have a fender reverb deluxe that i like to crank both the volume and reverb on. im in a room with almost no sound absorbtion and sheetrock walls...the reflections make me cringe. ill be moving into another sound treated room in due time..however, i have some questions after doing my experimentation. i was double micing the speaker with a 57 and a bluebird. i usually backed the bluebird back further so it would pick up more of the ambience to make the sound, sound "big"...i flicked that phase reverse switch on the pre for the bluebird, and put the 57 at an angle about 1 once from the grill. i feel like i still had phasing issues...is it possible that there are so many reflections in the room that those are causing phasing as well? i mean parrallel walls...the whole deal. I wasnt too satisfied with how the guitar sounded, and i was running the mics through a sebatron vmp 4000 into cubase. When i move to a better room...can i expect a much better sound? Also, do you usually record an amp set like this within a large room, or do you record it in a smaller space that is sound treated...in other words..would it be a good idea to record an amp in a more dead and dry vocal booth?
