V
		Valgrim
After electrocuting myself twice I figured I would maybe ask for some help...
I am setting up a hard disk recording scheme and was trying to test out my new crappy mixer and speakers. I currently am running it to a SB awe64 and the mixer is a cheap 4 channel jobbie with no pre-amp. I plan on upgrading the card soon but I wanted to test out how things are with what I have.
I first miced my amp (cheap mic, another thing I need to replace) and ran it into the mixers left/1st input. I ran a 1/4 to 1/8 cable to my SB input from the left output of the mixer. I got nothing. I then got the bright idea of trying to run a cord from the amps output into the mixer input. That's when the electrocution began. I then went direct into the mixer with my guitar. When I tried to play through the mixer I got absolutely no response from the level meter, yet I could hear(faintly)the guitar from the speakers. As a final test I just went from guitar to the lousy mic input on the SB. This worked great as far as volume went but that is not obviously a serious option
I'm thinking that maybe I needed to get a y cable to go from the left/right out on the mixer to the single input of the SB, instead of the left to input like I was doing. Or maybe I simply don't have enough power going into the input seeing as how the mixer doesn't have a preamp nor do I have a mic preamp. One last thing. Is it possible to go from the output of the amp into the in on the SB? That is what got me electrocuted so I figured I'd ask before I try it again.
As you can tell I have no idea what I'm doing, any help would be appreciated.
Valgrim
Valgrim
