stuntmixer
If I understand correctly, you are trying to not just take the empty spaces between musical events off the multi track page, you want to eliminate them, not have the session carry them around, right?
Try selecting the portion of the track you want to keep, splice it off from the rest of track (making sure it is locked in time) drag it to an empty track and then "make a unique copy" of it.
After doing that for all the peices you wish to keep, you will have a new track that is a collection of smaller waves instead of the longer one with silence. then delete the parent track from the session. I would keep it around in case...
If you are that worried about storage you should consider getting another hard drive. Generally the more processing, mixing down or copying you do the more your sounds will deteriorate. Digital file are still fragile
