Power Supply, Pedals and Noise Gate
Hi Enferno,
What kind of power supply are you using? Most pedals seem to work well with a regulated power supply. If your pedal needs one of them and you use a unregulated powersupply you are in for some serious hum.
I am not sure what the Digitech MM needs, you may be able to use a Boss
PSA.
You could try a simple test by running the pedal on the battery, then plug in the powersupply and see if your sound is exactely the same. Very often when using a powersupply your pedal will perform slightly different, as powersupplies seem to give a bit more power that the average battery.
Some of the older Boss pedals do want the unregulated powersupply,use a regulated one and again, you are into trouble.
bbop73 thanks for the great link!!
Using Noise-Gate;
I think in this case the noisegate would not help, as it will only trigger on Hiss and we are talking about Hum here which is a different matter altogether, but then again I could be sooooo wrong.
Cheers,
Eddie
