MysticRey
Hi I want to build a sound setup at home to speak and hear to multiple devices, and I was looking at a mixer to combine it with an external DAC and AMP for the DT 990 Pro 250 Ohm and to convert other devices signal, I was thinking about the Schitt Magni 3+ and Modi 3 which have nice inputs and outputs but of course, you can not use multiple inputs at once, you have to switch which for me its a little bit bad, I would also connect this to a mixer Behringer Xenyx Q502 USB or Yamaha AG 03 or 06 also I would use an XLR Mic. My question is not to spend useless money what do I need? I heard the Yamaha AG 03 and 06 have a good sound output for headphones and I'm not sure if I need the AMP from Schiitbut when I want to speak and hear for example simultaneously my PS4/5 or PC, for PC I just can use the USB from the mixer but for the console, I have to connect it probably with the mixer and the Behringer has more in and outputs but the Yamaha has top headphone quality right? And the mute monitoring button is great on the Yamaha can I somehow use this for the Behringer? Can someone say to me if I need the Yamaha AG 03/06 with a few cables and probably a cheap DAC for the console or the Behringer with the DAC and AMP from Schitt and then connecting this to the mixer, any other ideas? Which method should I use? And is the quality of the Yamaha stand-alone without a external DAC/AMP good enough without spending much money on external equipment??
