halfred
Well, I've sold my Microtrack 11 to one of my piano students and have moved on to an upgraded Tascam HD P2--- and within my limited experience, and in my humble opinion, this recorder kick ass. Dead quiet preamps, clear as a bell, great depth of tone. In case I haven't spoken with you yet, I'm recording solo acoustic classical piano on a Steinway B in my living room. I'm recording 5-7' out from the bend of the piano lid fully open, as well as some close micing with lid on short stick (to screen out mechanical noises.)
I was advised by several audio engineers (I'll be sending files eventually to someone for mastering), to make sure recordings peak at between -3 and -6 db. I'm experimenting with two Rode NT1A's alternately with two Pulsar 11 mics. The problem is that when I turn the gain up so the the recording is at the recommended peaks, the recocrder rattles and make wierd feedback noises, especially closer to -3db. The mics pick up a little of the noise in the recording although it is sort of faint. I take this occurence to mean that something aint right. It seems that the highest the peak can be is -12 db to not get the rattles and feedback noise. After my first encounter with the problem I tried turning the -20 db pads (previously it was on -0db.) But it was basically the same. I just had to turn up the gain and ,again, could not record with peak higher than -12db or I get the noises. Wondering what this means and would it be a problem sending files for mastering with a peak of 12db, for instance, would there not be enough volume to work with etc.
Also wondering about this. I made two recordings both peaking at 12db, one with -0 pad and one with -20 pad. Is there a practical difference? I've listened to so many sound samples I made but it seems to me that the one with-0 pad on had more punch to it , or could be my imagination at this point. Thanks for advice in advance
