AFIK, this is not a universal standard, but most manufacturers equate the "width" of any given Q setting with the bandwidth covered by the central 3dB of the bell curve of the boost or cut - i.e. the distance between the points on each sde of the cener of the curve where the curve has dropped (or raised, if it's a cut curve) by 3dB.I know that by adjusting the Q, one is adjusting the bandwith. But, how do Q and bandwith exactly relate to each other. What does one unit of Q equal in actual bandwith Hz?
OK, some basics... A bell filter with Q of 1 is fairly wide, a good starting point for a natural sounding boost or cut. Q of .5 is wider still. A 1 or 2 dB change with a Q of 1 or less will usually sound very natural. Q of 2 is narrower. IME the more narrow the filter's curve, the more artificial-sounding its effect will usually be. I rarely use a filter that's narrower than Q2 but many do....some basic tips regarding Q, as a starting point?
I don't think it means "boost all the frequencies between 5k-8k". But rather means, the center frequency for your parametric EQ should be somewhere between those frequences. Which frequency should it reall be on? That's where you need to judge it by listening to the material at hand. First off, what is your goal that you want to accomplish by boosting somewhere between 5k-8k? Next, does your material need that boost? If so, the next question then probably is "How do I find that center frequency?". To find where you need the center frequency, start with high Q (meaning a narrow Q), boost some and sweep the EQ between those frequencies while listening. Once you find the area where you get the characteristic you're after, then probably you'll need to lower the boost and widen the Q, again using your ears. In general wider Q tends to sound more natural, while narrow Q is great for targeting specific bothersome resonances (for example) and eliminating or minimizing them.I have some guide lines I am trying to use as a starting point. For example, if I want to boost "5K-8K, carefully", what does this mean? Start with a one db boost=carefully, and then maybe 2? or 3? What Q would give me a range of from 5K to 8K, when the frequency is set at 6.5K?
