altitude909
Best Advice Ever: RTFM
Gentlemen,
I am in the midst of doing some pretty in depth comparisons of midi timing of various USB interfaces on different platforms and have a some questions about the midi implementation in Reaper.
My tests involve using an externally clocked custom built device for measuring latency and jitter that sends a stream of midi messages to a midi in and measures their round trip time through the midi out via a midi track in the program. The issue I have with reaper is that the only method I have found to go through the program is to set up a track with the midi in and midi out set accordingly and then check the "monitor when recording" option. This however is giving me a horrendous amount of latency (10x more than other programs) and cannot seem to find any other way to do this. In other programs, I do not need to arm the track to monitor the midi signal so I suspect arming the track is causing problems. I can record normally. Any help is appreciated.
