Erik713 said:
Hey, Raw --
Congrats!! If you have a little time (and remember), can you post up what you did in terms of your mixing? It can be as meta (positions) or as micro (eq levels, etc.) as you want. I, and I think a lot of other new mixers here would sure appreciate it!
-E
Wow, I'm shocked to have been judged the best. Thanks Blue Bear! Here are a few notes off the top of my head as to what I did:
First, I attempted to gate the kick, as the snare was bleeding something fierce into the kick track. I found that the EQ curve that I wanted to use on the kick was causing the snare bleed to really kill the snare sound. I could not get a gate to trigger properly on the kick, even with filtering the sidechain. I finally decided to go in and draw volume curves on the kick track. That was very tedious, but proved effective in eliminating nearly all of the bleed on the kick track. After drawing the curves on the kick, I decided I might as well draw curves for all of the Tom tracks. That was much easier as the toms are not used near as much as the kick. I didn't draw volume curves for the snare. I wanted to, but I just didn't want to spend the time after the kick track wore me out. A gate proved pretty effective on the snare. I think there were a few false triggers, but nothing that got in the way. After I finished the volume curves on the kick, I applied some EQ and compression, can't remember the details off the top of my head.
The snare, as I mention, was gated. I used a pretty fast release. After the gate, the snare was just a pretty short burst. I used a gated reverb to lengthen out the decay of the gated snare. I then also applied a short reverb to snare. I think I rolled off quite a bit of low end on the snare. I thought it was quite boomy. I also applied a touch of compression.
I wrestled with the toms a little, but abandoned them pretty quickly. I just didn't dig their tone, and nothing I did seemed to really help them. I did draw volume curves to reduce the bleed. Also added a touch of reverb.
Overheads, I think I boosted a bit somewhere between 8-12kHz with a high shelf. Probably just a hint of compression. I can't remember for sure if I rolled off the lows, but I probably did.
I wasn't too keen on the bass guitar at first. I cranked up the low end quite a bit, then really spanked it with a couple of compressors. Suddenly, I felt the bass come to life, and actually found it quite useable. I think I also added a touch of distortion.
The
acoustic guitar was quite boomy. I cut out a bunch of the low end, and boosted the highs. I compressed it pretty hard, then sent a delayed version a little right of center, and the original a little to the left of center. That gave it a little stereo spread.
On the vocal, I know I boosted a high shelf around 14kHz, or so. Can't remember off hand if I did much else with the EQ. I compressed a bit. Also added a touch of a short plate patch. I used a doubler patch on the vocal at about 1:46, just to sort of bring the song to a head. Then I killed it after the drop out at about 2:26. I also ran the vocal through (gulp...) Auto-Tune. I used the automatic setting set pretty loose. Mostly just nudging the pitch back in the right direction. I didn't want to take the time to just draw in the offending pitches.
At the bridge section after the second chorus, I wanted to take the song up a notch. I took the snare track and made a copy of that section. I then reversed the snare track so it would play backwards. I then printed a long reverb from the snare to another file. I then reversed that reverb file. Now what I had was a file that was just reversed reverb that was preceding the actual snare track. I threw that reverse "pre-verb" in during that section just to give it a different feel. I followed that up with that long reverb shot sustaining over the drop out before the ending.
That's all I can think of for now.
Thanks Again Finster for providing the tracks! Giles for providing the bandwidth and prize! Blue Bear for Judging!
