Let's Get This Sorted...
OK Wayne, time to roll up the sleeves...
What system do you have? What sort of CPU do you have and how much RAM?
Have you checked the IRQ of the EWX? Is there any other hardware sharing the same IRQ?
What's the signal chain
from your EWX? That is, how are you monitoring the signal? Are you going through a mixer, an amp or whatever?
When you play the SONAR Tutorial5.bun, click on the EWX icon in your system tray and check that the meters are actually moving. That at least means you're getting signal from SONAR to the EWX.
I wouldn't worry too much about Plug & Pray, that's just Windows method of automatically recognising new hardware and setting it up for you. You
can install new hardware manually:
.My Computer>Control Panel>Add New Hardware.
Updating the EWX drivers, you must go into
My Computer>Control Panel>System> Click on the
Device Manager tab. Click on the
+ sign next to
Game, Video & Game Controllers. The EWX 24/96 should be in the list. Is there an exclamation mark next to it? Let's hope not
To update the driver double click on EWX24/96.
Click on the
Driver tab
Click on the
Update Driver button
You'll have to tell Windows where the driver is located. When you unzipped the file you will have designated a directory to unzip the files to. I always lob new drivers into directories so that I can find them later if I need to. For example, my EWX drivers are in a directory called
Terratec Drivers.
I note that the Tascam 788 is a digital recorder. Are you trying to import direct from the Tascam into SONAR? Or is it playing back the Tascam through the EWX that's not happening? The Tascam is fitted with an optical S/PDIF, and so too is the EWX! But I have a feeling if you use the optical/digital in on the EWX you can't connect a CD-ROM because the jumper only allows one or the other. Your EWX manual should clarify that.
Oh yes, the Tascam is 24-bit, 44.1kHz so you may need to set your bit depth in SONAR accordingly, I don't know anything about the Tascam. Maybe you should start a separate thread about importing from the Tascam into SONAR. Somebody must have had some success doing this.
First things first though, let's get some noise happening!
And to the rest of you interested readers, stay tuned for the next exciting episode.
BluesMeister
