M
		Milkman
Hey Everyone,
I recently upgraded from Sonar 4 to 5 and moved it to my laptop so I can track with less fan noise. I have a few problems....
Using MIDI, there is mad latency. Like I play a note on my keyboard (which sounds with the native sounds) and then the software synth seems to respond almost half a second later (TTS-1).
Also, I get frequent errors when I try to play or record that say "Unable to open audio playback device." I then have to restart my system and it is usually fixed.
Any help with these problems would be much appreciated! Sonar 5 is rocking other than that, so far.
Setup is Presonus Firepod....Laptop: Centrino 1.5ghz, 512 ram, 60gb hard drive, etc.
Thanks,
Milkman
Edit: One other problem that may be related: when I do the wave profiler test in Sonar, 44.1 khz is the only frequency that shows up as "available". Also, all of the ins/outs in Sonar are just labelled "BCo 0" - doesn't mention Firepod or the actual channel.
Thanks,
Milkman
