Problem with n-track!
starber
Unable to utilize my m-audio keystation 61es with n-track. Can not find option to specify USB MIDI controller for input. I set the sampling frequency in n-track to 48000Hz for my Creative Sound Blaster. My computer recognizes the USB hub and the keystation 61es controller, I'm also able to use piano roll without any problem. Looking at MTC/MIDI Clock Sync for possible options, but nothing workes. Thanks for any suggestions.
In the Preferences dialog under the Midi tab I believe there is a button for Midi devices, this is where you activate your input/output devices. You will also have to select a specific in/out device for each midi channel as well. I have an M-audio Radium(USB), works great. Make sure the keyboard is turned on before starting N-Track. If the keyboard isn't showing up in the input list try connecting with standard midi cables instead of USB.
