Hi,
I am having trouble connecting my new Korg R3 to Cubase SX3.
I have an E-MU0404 USB interface, this interface then connects to my laptop.
In the past I have connected a MIDI controller keyboard to the interface with a MIDI cable and then used VST instruments in Cubase.
Today, I have connected the Korg R3 and cannot get it to function properly. I have tried:
- 1 MIDI cable between the Korg R3 and E-MU interface (tried switching between input and output on both, plus every combination).
- Connecting the Korg R3 directly to the laptop with a USB cable.
- Connecting the Korg R3 to the interface with 2 standard jack audio cables (this gives sound, but it is crackled and distorted - the volume controls on the audio interface are turned down enough not to produce this yet still I get this distortion).
I am able to get the Korg R3 to send and record a MIDI signal to Cubase, so that this signal can then be used to play VSTs etc. But I cannot get the MIDI signal to play sounds from the Korg R3. Therefore making the Korg R3 unable to be recorded.
Are you able to suggest anything else I could try please?
Thanks, Mathew
Thanks, Mathew
