Hi, I'm having a problem with using the Studio Projects VTB-1 with the M-audio Omni I/O. I've been running a SP B1 into the Omni preamps, and the sound levels are to be expected (have to turn the knob to about half way in order to get decent vocal levels), but as soon as I try and use the VTB-1 with the Omni the levels just drop. If I use the VTB-1 to one of the line inputs, I have to put both Input and Output level on the preamp to almost full (both pointing right) to get any decent level. I've tried using the Mic Inputs 1 and 2 (as they are 1/4 TRS accepting too) but I had to actually turn up the volume on those to get a good signal.
I've checked using the VTB-1 with another card and it was no problem. I'm confused, somewhere along the line a lot of sound is dropping and this means lots of lovely hum and hiss. I don't know if its the Cable I'm using from Line out on the VTB-1 to the Omni (I used one unbalanced - like a guitar lead, and one balanced - althought one of the ends was 1/8" so I had to use a jack extension - would this cause problems?) or what.
Any help is great. Cheers!
