this is my first try at recording midi data and I'm having a little problem trying to get my midi data to record.I thought this would be fairly easy going by the book but I must have missed something.
This is my setup using a kurzwiel piano & roland jv1010 sound module, and midisport 2x2 usb:
1. the midi (in)going to the kurz.piano(channel1)
2. the midi (out) going to the jv1010(channel 1)
3. the midi (out) from the jv1010 going to-
4. the midi (in )of my midisport 2x2 usb(when i hit the piano keys,the midisport green light flashes,I guess that means it's working.I can also play the sound module from the kurz piano.
My sonar 1.0 set up:
inside my sonar midi track recording window it looks like this:
1. the (R) recording light is turned on(red)
2. (CH) is set to none for now but I tryed other channels already.
3. (PCH) nothing
4. (BNk) nothing
5. (VOL) 127
6. (PAN) Centered
7. (VEL) 0
8. (KEY) 0
9. (time)0
10. (FX) nothing
11. (CHR) 0
12. (REV) 0
13. (IN) Midi omni for now but I tryed (ch 1) & (none)
14. (OUT) 1 out A USB midisport 2x2 (I dont have any connection to this port. the only connection is from the sound module to the 1 (in)midisport A USB.
under options/midi devices:
1.inputs: in a midisport,in B midisport(highlighted)
2.outputs: out a midisport,out B midisport(highlighted)
under options/instruments
1.output ch: out a usb midisport
2.user instrument: default
under options/project:
1.clock: internal
2.midi input: all channels are checked
3.midi note: port 1,(Ch) 10
When I record using just a midi track it doesnt record any data.I'm not concerned about hearing any sounds at this point ,I'm just trying to see if i can record midi data.I have no problem recording audio.Any help would be cool.
3. (PCH) nothing
4. (BNk) nothing
5. (VOL) 127
6. (PAN) Centered
7. (VEL) 0
8. (KEY) 0
9. (time)0
10. (FX) nothing
11. (CHR) 0
12. (REV) 0
1.clock: internal
