Roland VS-2000 Master with Roland MV-8800
Syncing MV-8800 To
VS-2000 CD
Connect MV-8800 Midi In To Out Of VS-2000
VS-2000 Becomes The Master Controllor
MV-8800 Sync Set Up
Sync Mode To Slave-Mid- Midi
Midi Clock A & B On
Roland VS-2000 Set UP
Sync Mode INT
MIDI OUT SYNE GEN SET TO Midi Clock
Roland VS-2000 With Protools LE. And MV-8800/ Motif ES7
Roland VS-2000 Master Controller
Roland VS-2000CD Midi Out/Thru Into Protools Midi In.
Set Roland VS-2000 SHIFT UTILITY No#6 Sync Prm Select MTC Parameter
This Should get Roland VS-2000CD And Protools Clock Sync.
My Outboard Drum Machine Gear Roland MV-8800
Roland MV-8800 Midi In - Into Protools Midi Out. I use Output 2 On Protools
Set Roland MV-8800 Sync Mode to Slave- MTC (Midi)
Midi Clock Midi A On - Midi B On
MTC Midi A On- Midi B On
If you don’t no this part it will drive you crazy. Press Play On The Roland MV-8800 Drum Machine, light will start to blink. Then Press Play or Record On the Roland VS-2000 There you go All 4 Are Playing and Sync Up. If you have a Keyboard just leave it the same way it was hook up with your Motif And Your Roland MV-8800 The only thing change between those two is you just took out the Midi Input That goes to
the Roland MV-8800 to switch to the Midi out so you can run that Into your Protools.
Hope this helps
GatlinProduction Recording Studio’s The Sync Master
HERE IS A GREAT RESON FOR THIS AND THIS IS HOW I LIKE TO DO THIS BECAUSE ITS A BUDGIT SAVER.
When Syncing up to Protools using your Mac Or PC That sync gets off sometimes
and on or more instruments get left behind. So I use the ROLAND VS-2000 SYNC CLOCK TO BE THE MASTER hint hint IT TAKE A LICK’EN AND KEEPS ON TICK’IN.
Protools Syncing is like playing Musical Cheers You never when it’s going to Top, Freeze ok Let’s shut Down Know I need a Reboot. There goes your project.
Here the cool part Use the Clock Sync on the VS-2000 Have your Audio going into Protools. Cool ha. Or Use your Audio Into Clear Pristine Roland VS Then Import Them Audio out on a CD. Upload them into Protools. Down you have Clear Digital And Them Warm them up. Check it you No Noise.
