F
FreshChops
Hey all, just getting started here. I love reading on here, but I'm getting active now and, well, am starting with a pretty basic question.
I have a variety of guitar amps that I often like to power simultaneously. I use a stereo looper (EHX 2800) and deal with a lot of ground hum tying in amps powered by different wall sockets and different power supplies. I guess the obvious solution would be to tie all of the amps power into one power block. My thing is, I have a small phobia "blowing things"!
My wall sockets are typical grounded, two prong outlets. I could probably get into the circuit breaker for breakdown of what's covering those areas if helpful, but in short, I'm pretty ignorant regarding power and ironically, don't like getting electrocuted
So in summary, I am powering combinations of 30 watt to 100 watt tube amps. In most cases, I would have 4 amps going.... yes, even tied into one signal, or the looper. Commonly, (2) 30 watt; (2) 100 watt
Would plugging them into the same power source eliminate ground hum between the amps?
Is there a general rule of thumb regarding how much to power from one outlet?
A third "?".... in addition to the tube guitar amps, could I / should I also power my pedal board from the same outlet. I have some high wattage pedals, like tube powered compressors.....
and another: In addition to this..... I have a high wattage bass amp, a 1200 watt SS bass power amp. aaaaa, can this be throw on the same outlet?
Honestly, pardon my electrician ignorance, but I'm serious and wouldn't be surprised if I'm overthinking this and there are little amp / gear limitations per outlet, or the reality that I should split loads as often as possible.... please enlighten me....
I also have a lot of options for quality power supplies, like good surge protection blocks. I even have a couple good battery backup supplies... Would these be benificial? What about a good "Furman" to power all amps. Would this help, or does it come down to limitations per outlet?
Thanks for any input..... my home recording studio is quickly coming together, I'm excited and I swear any other issues won't be so long winded....
